  3. How to get selected pins of the instance
  • Views 17425
fatcat1206
fatcat1206 over 10 years ago
Hi All
I want to get the selected pins of an instance in the schematic by skill script.
After selecting the pins, the "geGetSelSet()" returns nil.
I take a look in the post, and find this question has been asked in "Objects selected in schematic, but car(selectedSet()) returns Nil"
Unfortunately, the script in the reply does not tell how to get selected pins, it treats all the pins from the selected instance.
As I want to only use part of pins from an instance as an input for my code, it's highly appreciated if someone can provide an answer.
P.S I notice that the API "schHiCreateWireStubs()" can take selected pins as input, also the "Property Editor" also react for such selection. I was wondering what is the correct function to visit the selected set in the database.
Best Regards
Yi
  • skillUser
    skillUser over 10 years ago
    Hi Yi,
    geGetObjectSelectedSet() will get you a non-nil result, but you will have to look at the docs for how to use it (sorry, I've no examples).
    Lawrence.
  • fatcat1206
    Hi Lawrence
    Thank you for your quick reply.
    I have tried the function and have found the document.
    It's exactly what I need.
    Best Regards
    Yi
