  3. Delete/disable a sub menu item
  • Views 2552
loboveena
loboveena over 10 years ago
There are a set of preloaded menus and I want to gray/disable one of the sub-menu item. This is a sub menu item something like
Virtuoso Layout -> Utils ->Tools -> MoveViaBy0p1. I tried using hiDisableMenuItem( utils 'Tools ). This disables 'Tools menu but there are other sub menus in here which should remain enabled. How do I disable  'MoveViaBy0p1 sub menu ?
Also, is there a way I can find out the preloaded menu names/menus loaded from my cadence session ?
Veena
    Veena,
    That presumably is a custom menu in the first place (since the Utils menu is not one of Cadence's). Anyway, you can find out the menus in your window by calling:
    hiGetBannerMenus(hiGetCurrentWindow())
    having found the name of your variable for the starting pulldown menu (sounds as if you have that already, utils) then you can inspect the menu items within that list:
    utils->_menuItemList
    In your example, that was probably Tools. So you can then get to the slider menu:
    utils->Tools->hiSubMenu
    For this you can also find ->_menuItemList - so if that showed MoveViaByOp1 you'd do:
    hiDisableMenuItem(utils->Tools->hiSubMenu 'MoveViaByOp1)
  • loboveena
    Thank you very much for your help.
    --Veena
