  3. Change lower cell edit mode
  • Views 15875
psill000
psill000 over 10 years ago
I have a script that changes a layers coloring hierarchically so all the shapes under point will be changed.
However, if a lower cell was not opened in edit mode the cell looks changed but is not changed if you close the cell and reopen the cell.
Is there a way to change the edit mode of the lower cell?
Is there a skill function to change the edit mode of a cellview?
geChangeEditMode only seems to work on the top level cellview.
Paul
    Paul,
    dbReopen() is what  you want.
