  3. Dynamic Selection assistant - change order of items in Data...
  • Views 1104
Dynamic Selection assistant - change order of items in Data list?
yeh1
yeh1 over 10 years ago
Hi, in the Dynamic Selection assistant, the default order of items in the Data list seems to have netName at the end, e.g. Pin-Rectangle-M2/pin-VDD.  Is there some .cdsenv or skill function to put the net name at the beginning, e.g. VDD-M2/pin-Rectangle-Pin?  Typically I want to know net name and layer name, and the other info is less relevant, and putting netName at the beginning would allow a narrower Dynamic Selection window on my workspace.  Thanks.
    No, this is not configurable. It would need an enhancement to configure it - I've not found any similar requests currently, so I would suggest you contact customer support if you want this.
    Kind Regards,
