  3. Multipart path behaves as flat
  • Views 15243
RVERP
RVERP over 10 years ago
Sometimes, multipart path in my layout behave as flat. For example, when i move a mpp, only the main path moves, and all the subparts appear to stay in the same place.
If I restart virtuoso, the mpp move behaves normal again, but the subparts are permanently shifted.
This breakup only appears when I use custom skill code to draw rodPaths. Also mpp that are already in place before the rodPath procedure are also affected.
Any idea what is the cause of this?
  • RVERP
    But when I make a copy of the mpp with shifted subparts, the copy is normal again???
    I've never seen this behaviour. Which version of the tools are you using? (Help->About in the CIW will tell you the subversion)
  • RVERP
    My version is 6.1.6-64b.500.12
