  3. Skill code to run DRC, LVS, PEX and resimulate with the...
  • Views 18690
Skill code to run DRC, LVS, PEX and resimulate with the produced calibre view
Inas Mohammed
Inas Mohammed over 10 years ago
Please i need help in the following
I have a schematic and layout costumly done, but i need to automate the verification flow.
So what i thought about having a skill code having the sch. and layout view as entries but i don't know how to invoke calibre DRC and LVS and PEX to run and also ask for opening the RVE.
Then how can i invoke spectre and add the calibre pexed view in it to resimulate with it?
BR,
Inas
    I thought I'd seen a similar post a few days ago, but I can't find it.  I don't know what "costumly done" means, but in general questions about invoking Calibre DRC, LVS and PEX should be asked on a Mentor graphics forum.
    Running simulation with a Calibre extracted view would typically just be a matter of creating a config view (with the hierarchy editor) and picking that view as the view to use for the cell you've extracted. Then opening ADE with the config view as the view you're simulating, and everything would work fine - this can be done in ADE or OCEAN. You can also just run ADE from your test bench and change the view switch list in setup->environment to alter the order the views are picked globally, but I would generally suggest using a config view for this kind of thing.
  • Inas Mohammed
    I meant by "costumly done" is that its made manually not using a code. Can you please tell me the link for Mentor Graphics forum?
    Try this:
