  3. Trigger for refreshing technology information
  • Views 15882
Adrian Nistor
Adrian Nistor over 10 years ago
We are using incremental techfiles, for some technical reasons we can not use leSetLSW to set the order of the layers, so we have the problem that the layer order is not anymore the needed one.
That's why we made a function to fix the layer order and we run that function on virtuoso startup.
The new problem is that if the user is doing a "Close Data" including the techfile, or if he's doing from Library Manager, View - Refresh and he checks also: "Refresh all in memory technology files" , then the order of the layers is again lost, and we need to re-run the sorting function.
So the question:
Is it possible to register a trigger for Refreshing the technology information, or at least for the menu entries: "Close Data" and LibMgr-View-Refresh ?
Thank you,
BR
Adrian
    Hi Adrian,
    I don't think there's a trigger for when the (binary) tech file is loaded into memory or when it's purged. There's a tech file for when an ASCII tech file is loaded, and for when it's attached or referenced to another library.
    I think you'd have to request this via customer support as an enhancement request. I can see why you want it, but don't think it's possible right now.
    There is a purge trigger for cellViews - so there are similar ideas for cellView database ids.
  • Adrian Nistor
    Thanks for the answer, Andrew !
  • dmay
    dmay over 10 years ago
    We have done this very thing with a bit of a Skill hack.
    First, we replaced the Close Data menu item with our own command. Our command simply manipulates the Cadence form to call our custom callback. Our custom callback calls the original callback, but then reloads techfile settings that we need.
    procedure(myddCloseData()
     let((port)
      port = outfile("/tmp/ddsCloseData.il")
      fprintf(port "ddsHiCloseData()\n")
      fprintf(port "ddsCloseDataForm->_doneAction = \"my_ddCloseDataCB()\"")
      close(port)
      load("/tmp/ddsCloseData.il")
      sh("rm -f /tmp/ddsCloseData.il")
    )); proc
    The above hack works and was written a long time ago. When that code is loaded, it successfully modifies the _doneAction on the form after the form is invoked. If you did this in Skill, the command to change the _doneAction wouldn't happen until after the form was dismissed. However, you can use hiRegTimer to do the same thing. I think the following two lines of Skill will accomplish the same thing (untested).
    hiRegTimer("ddsCloseDataForm->_doneAction = \"my_ddCloseDataCB()\"" 1)
    ddsHiCloseData()
    Finally, your callback:
    procedure(my_ddCloseDataCB()
     let((libList libInitFile libName selItems)
      ;pre-process the form
      selItems = ddsCloseDataForm->CDCV->value
      foreach(i selItems
        libList = MSutUniqueList(cons(car(nth(i ddsCloseDataForm->CDCV->choices)) libList))
      ;Call the original callback
      ddsCloseDataFormCB()
      ;Add your post processing next
      ;Maybe you need to see if your techfile is in the libList
    )); proc
    Derek
