  3. How to remove backslash , \n , " characters from given ...
  • Views 3428
How to remove backslash , \n , " characters from given line
San
San over 10 years ago
I am reading a file and looking for a line as follows :
myFile=infile("/sample/file.txt")
while(gets(line myFile)
     if(rexMatchp("IPTECH" line) then myLine=line)
output is :
"INCLUDE \"$IPTECH/123/calibre_lvs/deckfile.txt\"\n"
Now I just want
"$IPTECH/123/calibre_lvs/deckfile.txt"
I tried different functions for rexMatchp , rexReplace etc but no success.
Please guide me through this.
Sanket
    If you're using IC61X I'd recommend using the PCRE functions:
    pattern=pcreCompile("^[^\"]*\"([^\"]*)\"")
    pcreExecute(pattern line) => t
    pcreSubstitute(pattern "\\1") =>
    If you are using IC5141 you'd have to use rex functions instead (which are more limited).
    rexCompile("^[^\"]*\"\\([^\"]*\\)\"")
    rexExecute(line) => t
    rexSubstitute("\\1") =>
    Note that the pattern for rexCompile is slightly different - the grouping parentheses have to be escaped (hence the double backslash before them).
    A textual description of the pattern is beginning of the line (^) followed by any number of characters other than quote ([^\"]*), followed by a quote, followed by a group (surrounded by parentheses) which is any number of characters other than quote - followed by another quote.
    The \\1 in the "Substitute" function recalls the matched pattern in the first group.
  • San
    That worked as expected.
    Thanks a lot Andrew for clear explanation. I appreciate your help.
    Sanket
