  3. How to save output of command line to a variable using SKILL...
  • Views 15904
How to save output of command line to a variable using SKILL (non-interactive)
San
San over 10 years ago
I want to save command line output of following to a variable in SKILL code.
I want to use output of   echo $ENV1/sample/$ENV2/file.txt  command line command in my SKILL code.
I tried csh("echo  $ENV1/sample/$ENV2/file.txt")  but it just prints the output to command line.
How do I save that output to a variable in SKILL to use it later in code.
thanks
Sanket
  • San
    hi all,
    I was able to find similar problem by following name.
     "Assign Shell output to Ocean variable"
    Andrew provided the solution to that.
    Same solution worked for me.
    Thanks Andrew.
