  3. flattening an instance and then removing certain layers
  • Views 21488
ssarik
ssarik over 10 years ago
I am trying to create an instance of a cellview in my layout (the cel view can contain one or more pcells) and then remove certain layers from it (like all the metal 2 and metal 3 layers).
The process which I am following is as follows:
1. Create an instance of the object in my cellview
2. Flatten the instance till 10 level of hierarchy (10 is a randomly chosen number, my hierarchy will not exceed 10)
3. Get the list of all the db objects in the cellview
4. delete all the shapes with layer type as metal2 or metal3
5. save and close
I am able to create the instance in my cell view and it is flattened but the shapes are not removed.
I get the following error in the console window:
dbGetq: object is a purged/freed object - db:0x21776ca2
type: nil
dbGetq: object is a purged/freed object - db:0x21776ca3
*WARNING* (DB-270063): dbDeleteObject: Invalid database object 0
type: nil
dbGetq: object is a purged/freed object - db:0x21776ca4
Below is my code:
cellview = dbOpenCellViewByType( libraryName viewname1 "layout" "maskLayout" "w")
instA2 = dbOpenCellViewByType( libraryName viewname2 "layout" "maskLayout" "r" )
instIdA2 = dbCreateInst(cellview instA2 "inst1" list(0 0) "R0" 1)
dbFlattenInst(instIdA2 10 t t)
allShapes = cellview~>shapes
(foreach shape all_shapes
   if((member(shape~>layerName toRetain) == nil) then
       dbDeleteObject(shape)
dbClose(inst)
dbSave(cellview)
dbClose(cellview)
    The likely cause of this is that your code is using inconsistent variables:
    As you can see, the variable names are different... so probably all_shapes contains a different list?
    Your code is not the most efficient either - it would be better to iterate through the layer purpose pairs (cellView~>lpps), and then see if that lpp is one to be retained or not, and if not then iterate through all the shapes on that lpp and delete them.
  • ssarik
    Thanks Andrew.
    Another query.
    Say my cellview has two instances I1 and I2. I want to flatten them and store the dbIds of the resulting shapes in two different variables.
    dbIdI1 = All from I1
    dbId2 = All from I2
    How can I do this because dbflatten returns t/nil?
    Shahbaz
    There was an enhancement CCR for this in the past, but it was rolled into another CCR which only implemented part of the requested functionality (dbFlattenInst2). I've filed enhancement CCR 1530372 to make up for the earlier one having been only partially fixed.
    In the meantime, you can use this code, which has similar semantics to dbFlattenInst2 (which was added in IC6.1.6). The usage would be something like this:
    figsA=abFlattenInst2(inset 5 `(nil flattenVias t flattenPCells t))
    /* abFlattenInst2.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Jan 25, 2016
    Modified
    By
    Like dbFlattenInst2 but returns a list of the resulting figures.
    Has same call signature as dbFlattenInst2
    SCCS Info: @(#) abFlattenInst2.il 01/25/16.11:41:11 1.1
    *         abFlattenInst2(instId levels options "dxg")          *
    *    Wrapper around dbFlattenInst2 to return a list of the     *
    *                       resulting shapes                       *
    procedure(abFlattenInst2(instId levels options "dxg")
        let((cv bBox (before makeTable('before nil)))
            cv=instId~>cellView
            bBox=instId~>bBox
            foreach(fig dbProduceOverlap(cv bBox 0)
                before[fig]=t
            when(dbFlattenInst2(instId levels options)
                setof(fig dbProduceOverlap(cv bBox 0)
                    !before[fig]
