  3. Finding the connectivity pattern between different instances...
  • Views 15159
Finding the connectivity pattern between different instances in a cell view
ssarik
ssarik over 10 years ago
I am using virtuoso 6.1.6
Here is what I want to do (pardon me if its a no brainier)
Lets say I have three different instance A1, A2 and A3 in my cellview.
They are placed horizontally as A1-A2-A3, some shapes present in A2 overlaps with A1 and some shapes overlaps with A3 in such a way that A1 - A3 gets connected.
Ex: An M1 shape(a1_m1) of A1 overlaps with a M1 shape(a2_m1) in A2.
This M1 shape(a2_m1) is connected to a M2 shape(a2_m2) in A2 through via1(a2-via1),
finally the M2 shape(a2_m2) overlaps with a M2 shape(a3_m2) in A3.
Here we have a connection from A1 to A3  as (M1-via1-M2), in terms of shape it is a1-m1 -> a2-m1 -> a2-via1->a2_m2->a3-m2.
I want to determine the connectivity of A1-A3 in terms of  shapes i.e a1-m1 -> a2-m1 -> a2-via1->a2_m2->a3-m2, without flattening A1,A2 or A3.
PS: I think "marknet" internally uses a similar mechanism to display connectivity.
Shahbaz Sarik
    Shahbaz,
    Please do not double post your questions. They won't get answered any more quickly - in fact it's likely to result in confusion and you're more likely to get ignored.
    This is the same as http://community.cadence.com/cadence_technology_forums/f/48/p/35116/1345203#1345203
    I would join the posts but a current problem with the system means that it tends to delete the post instead!
  • ssarik
    Sorry Andrew,
    I won't repeat it.
