  3. User post install trigger 'add_my_menu' is already registered...
  • Views 2335
User post install trigger 'add_my_menu' is already registered for viewType maskLayout
danmac
danmac over 10 years ago
When I load a script to add a menu "add_my_menu" in the ciw window, it reports warning:
code like this:
procedure(add_layout_menu(args)
hiInsertBannerMenu((getCurrentWindow) 'trPulldownMenu (hiGetNumMenus (getCurrentWindow)));
deRegUserTriggers("maskLayout" nil nil 'add_layout_menu)
Could you please check this?
Thanks!
danmac
    You must be calling the deRegUserTriggers more than once with the same function name. The solution is obvious - don't do that or call deUnRegUserTriggers first.
  • danmac
    Andrew, thanks for your help, and I use deUnReg**** and it works. But the menu added by other guys are lost after I do this. How can I make a another new menu just for myself, and not loss the menu add by other guys at the same time.
    In that case, don't call deUnRegUserTriggers but instead call your function something else! Isn't that fairly obvious?
    BTW, the approach being used is incorrect - you're using a user post-install trigger, whereas you should use the user menu trigger for this. That's the third argument to deRegUserTriggers so your code should be like this:
    procedure(MY_add_layout_menu(args)
    list(MYPulldownMenu)
    deRegUserTriggers("maskLayout" nil MY_add_layout_menu)
    Of course, make sure your variable containing the menu is unique too.
    The only exception to what I'm saying is if you're using an ancient version - I think it was in IC446 we changed to support multiple user triggers of each type being registered, but I'd be surprised if you're using a 14-15 year old release (at least without mentioning that).
  • danmac
    Thanks very much!
