  3. How to locate a file that is loaded using loadi?
  • Views 17306
Sheppy
Sheppy over 10 years ago
In one of the PDK we're using, somewhere in the entire chain of loading files/code, a certain file is loaded using this syntax:
loadi( "fileX.il" )
So, loadi() looks through the skillPath to find the file in one of the specified directories.
I need to locate this file in order to find a bug in one of the procedures which is in that file.
The skillPath in this particular PDK is very (very) long when I check it with getSkillPath() (it has duplicates in it, how dodgy...). I can write some code to print the location of the file:
printf( "file fileX.il is here = %s\n" car( foreach( mapcan path getSkillPath() when( isFile("fileX.il" list( path ) ) list( path ) ) ) ) )
This has one drawback: it will not show all locations if it is present at multiple locations. Removing the car() will do this trick (the %s must be swapped with %L too), although the formatting will not look nice with all double quotes.
Is there a standard SKILL function (procedure) that does the exact same thing? Procedure could be called getFilePath()...
Thanks in advance.
With kind regards,
Sjoerd
    Hi Sjoerd,
    There's no standard function, but there is this COS solution (guess who wrote it?). Again, it only tells you the first match - the code is intended to work whether you give an absolute path, a few relative path combos or have let it find it using the SKILL path.
