  3. SKILL command to get the schematic view associated with...
  • Views 17746
SKILL command to get the schematic view associated with a Symbol
Manikk0501
Manikk0501 over 10 years ago
             Is there any SKILL which will fetch the Schematic view associated with the Symbol View?
Thanks and Regards,
Manikandan Kuzandhaivelu
  • skillUser
    skillUser over 10 years ago
    Hi Manikandan,
    Yes, but the approach depends on a couple of things:
    1) what is your staring point, the symbol cellview (e.g. open in a window) or the library-level view (e.g. in the Library Browser) ?
    2) is the schematic view called "schematic", or do you need to allow for any name?
    Also, I will assume your version is IC6.1.x or ICADV12.x, and I'm assuming that the symbol and schematic reside in the same library (a reasonable assumption I think!)
    Assuming a symbol cellview starting point, e.g.
    symCv = dbOpenCellViewByType("mylib" "mycell" "symbol")
    You might find the schematic like this:
    ;; check that the schematic cellview exists (using the name "schematic" for the view name)
    when(ddGetObj(symCv~>libName symCv~>cellName "schematic")
    schCv = dbOpenCellViewByType(symCv~>libName symCv~>cellName "schematic")
    The latter (schCv) is the cellview database id (cvId) of the schematic.
    Or, not assuming the name is "schematic" (but assuming there is just one such view), and assuming a library-level view starting point:
    schDd = car(
      setof(v ddGetObj("mylib" "mycell" "symbol")~>cell~>views
    member("sch.oa" v~>files~>name) ) )
    The latter (schDd) is the cell ddId of the schematic.
    Hopefully this gives you some ideas, and of course YMMV.
    Best regards,
    Lawrence.
