  3. decrypting a callback function
  • Views 15859
knight499
knight499 over 10 years ago
Hi Cadence Community --
We have a factory PDK and don't want to load the whole upgrade and run the Pas migration on all the schematics at this time because we are in the middle of designing. We just want the one new device. I copied in the device and models and it generates the layout so that's great. But of course the callbacks fail. I can't update the length or width for the device.
I can see with the strings command that this callback is in a particular context file and I can see quite a lot of the strings used by the callback. But, what a hassle to have to rewrite the callback. There is so much work here all of the time.
I know we have all of this dbWriteSkill, etc for layout pcells and that's nice. Is there anything like that to decrypt the callback function from out of the conext file?
Thanks for reading my posting && best wishes
Marion
  • skillUser
    skillUser over 10 years ago
    Hi Marion,
    you can't really reverse engineer a context file, nor can you only load part of it. You cannot read SKILL loaded from a context file (it is read-protected), and you may not even be able to tell what functions are defined in a SKILL context file.  For obvious legal reasons (i.e the PDK provider not wanting access to their IP) you should not attempt to reverse engineer a SKILL context file.  Without knowing any of the details I can't really say, but I would guess that you could load the context file using loadContext() and this would define the callbacks you need?  If this does not work you might contact the foundry and ask if they could supply an incremental update to the PDK, e.g. a small context with only the changes or new bits, and the cells that were added, etc.
    For those that don't know, a SKILL context file is byte-code compiled SKILL, it is a binary (machine readable) representation of the state of the SKILL virtual machine at the time it was 'compiled' which includes function definitions and possibly variables too.  Functions defined in a SKILL context file are automatically read-protected, and thus cannot be pretty-printed or otherwise 'decrypted' for viewing.
    Hopefully this helps and answers your questions?
    Lawrence.
