  3. Script Skill : drawing a path or rectangle in layout's ...
  • Views 12025
Script Skill : drawing a path or rectangle in layout's View
tahm
tahm over 10 years ago
I am beginner in script skill! I want a script skill that can draw a path or rectangle in a given layout view, with a given layer's purpose and dimensions.
How can excute it ? Because i try to execute some code in Virtuoso 6.1.6-64b-Log but I want an easier way via file.
Can someone help me?
Mohammed,
  • skillUser
    skillUser over 10 years ago
    Hi Mohammed,
    Your description/requirements are a bit vague.  You can open a cellview non-graphically using the dbOpenCellViewByType() function and then you can create a rectangle using dbCreateRect() or a path using dbCreatePath() or a path seg using dbCreatePathSeg().  The cellview (layout) can then be saved to disk using dbSave().
    I recommend that you look at the documentation for each of these functions, but here's a really simple example:
    let( (cv)
      ;; the variable 'cv' is local to this let statement, i.e. this code does not create or use a global variable 'cv'
      cv = dbOpenCellViewByType("mylib" "mycell" "layout" "maskLayout" "a") ;; opens for edit, or creates layout
      dbCreatePath(cv list("M1" "drawing") list(0:0 1:0) 0.2)
      dbCreatePathSeg(cv list("M1" "drawing") 0:0 1:0 0.2 "truncate" "truncate")
      dbCreateRect(cv list("M1" "drawing") list(0:0 1:1))
    dbSave(cv) ); let
    Hopefully this can help you to get started? You could create a procedure that accepts arguments for the layer used, the points required etc. Make your code structured and re-usable by not relying on global variables and grouping commonly used or repeatedly used code sections into procedures - again look at the documentation for help on this.
    Best regards,
    Lawrence.
  • tahm
    Thanks a lot Lawrence ! What do you mean with the documentation, because, actually the only doc that I have is with Cadence Skill API Finder, there are another docs?
  • skillUser
    What does the CIW Help menu show? Isn't there a "Virtuoso Documentation" entry? Have you tried "cdnshelp" from the command line? You could also try looking for the documentation files (HTML and PDF) in your installation directory, e.g. "ls `cds_root virtuoso`/doc".
