  3. Button widgets in SKILL GUI is not working
  • Views 15270
Manikk0501
Manikk0501 over 10 years ago
I created a GUI.. If i execute a procedure from CIW(), it is running w/o issues.. But if i attach it to the callback of hiCreateAppForm(), it is not working.. Moreover, if i click 'Cancel' GUI is not getting closed.. I am not getting any error msgs in CIW.Can anyone help me on this?
  • skillUser
    skillUser over 10 years ago
    I don't think that this forum is followed by clairvoyants who happen to know SKILL - without seeing the code, how do you expect people to be able to help you?
    Have you tried quitting the session and starting afresh?  I've seen cases where Cancel does not cancel a form, but typically during development, say when setting the form variable to 'unbound while it is still being displayed (quitting is the only way I know around that problem).
    Lawrence.
    I agree with Lawrence. The one thing that occurred to me was whether you had unwittingly made the variable used to store the form (the ?name argument for the form created with hiCreateAppForm()) a local variable (in a let() or a prog()). That can also cause the form not to be removable because any interactions with the form data structures fail when executed in the global scope.
    However, this is a wild guess without seeing any code whatsoever.
