  3. SKILL program to cycle around a list of instructions, prompted...
  • Views 15511
SKILL program to cycle around a list of instructions, prompted by the user
DerekH
DerekH over 10 years ago
Hi everyone,
This is my first post. I'm a lowly analogue designer who uses cadence every day, but I've never done any skill programming, so I need the help of some of you power-users!
My immediate need is for a simple program that does the following: I want to highlight devices consecutively within a schematic, with a user driven prompt that moves on to highlight the next one.
I've got a list of these devices and I have the function which highlights each device in the schematic hierarchy. So far I've put them into a .il file, which looks a bit like this:
FindInHierarchy("<x1>mn1")
FindInHierarchy("<x1.x2>mn2")
FindInHierarchy("<x1>mn3")
where the FindInHierarchy function is already written (not by me!) and takes the user to the device in question in the schematic.
When I load the file into virtuoso it runs through the list super fast and I'm left looking at the final device in the list (which makes sense).
What I'm after is a function which goes in between each of these instructions, that, say, pops up a form or button which prompts the user to push "next" or something and then the program executes the next instruction. Then the user pushes the button again to move on to the next one and so on.
This would enable me to interrogate each device in turn and then move onto the next one when I'm finished with it, until I get to the end of the list. Ideally the list would wrap around when it got to the bottom, and there would be a finish button or something to push which would exit the program.
I hope this makes sense.
Many thanks!
Derek
    You could use hiDisplayAppDBox() with a modal dialogStyle:
    hiDisplayAppDBox(?name 'CCFpromptForNext ?dboxBanner "Next" ?dboxText "move onto next" ?dialogStyle 'modal ?dialogType hicInformationDialog)
    That said, I'm not sure this is quite what you want because it will block the UI. So what you might want is something like this:
    procedure(CCFvisitListOfNames(listOfNames)
      FindInHierarchy(car(listOfNames))
      hiDisplayAppDBox(
        ?name 'CCFmoveToNext
        ?dboxBanner sprintf(nil "Showing %s" car(listOfNames))
        ?dboxText sprintf(nil "Current instance %s.\nOK to move to next?"
          car(listOfNames))
       ?dialogStyle 'modeless
       ?callback sprintf(nil "CCFvisitListOfNames('%L)" cdr(listOfNames))
       ?dialogType hicQuestionDialog
       ?buttonLayout 'OKCancel
    Then do:
    CCFvisitListOfNames('(
     "<x1>mn1"
     "<x1.x2>mn2"
     "<x1>mn3"
    The modeless dialog box should stop it freezing the UI, and using the callback to move onto the next will then be fired if you hit OK. Hitting Cancel will stop it moving onto the next.
  • DerekH
    That's exactly what I wanted! Thanks very much for your prompt reply.
    Derek
