  3. Edit in place to specific instance
  • Replies 11
  • Views 25306
psill000
psill000 over 10 years ago
Is there a function to go to a specific instance with edit in place in layout.
If several instances overlap at the same point, I want to go to a specific cell to edit shapes/vias/pins.
Paul
    Andrew Beckett over 6 years ago in reply to Andrew Beckett
    Hi Fari,
    I checked, and product engineering have said that this should be documented (I filed CCR 2319210 to make it public and documented). To enable it, you can use:
    envSetVal("layout" "descendEIPPopupSelectionWindow" 'cyclic "fullform")
    You can also use "shortform" as an alternative - this gives a smaller form with a bit less information. The default is "off" (there's one other choice "highlightedobject" but I don't think that's what you want).
