  3. Are there any SKILL functions for Auto routing in Non-graphical...
  • Subscribers 150
  • Views 18852
Are there any SKILL functions for Auto routing in Non-graphical mode ?
San
San over 10 years ago
Hi all,
I am working on some automation to generate 100's of test cases.
I want to use VSR auto route feature in non-graphical mode. I was not able to find any SKILL functions for that.
I am aware of rdeSource command using pre defined tcl file approach which is interactive.
Please guide.
Sanket
    I thought this had come up before and saw that you'd asked the same question a while back:
    I answer a (somewhat) similar question recently too:
    If you have access to the router, you could select multiple nets and then call lxSelectedRoute() or lxSelectedRouteNet() if you have shapes selected instead. The code I mention above does them one at a time, but better would be to select them all and call the function.
    I'm not sure if there is a function to call the router without a form (probably should be, but from a quick check I couldn't find it) for all nets.
  • San
    This is definitely helpful information . I appreciate it..
    Sanket
  • DineshBabu
    DineshBabu over 10 years ago
    My question is similar to what was asked before. I am looking for a solution to do the routing part in non-interactive mode.
    Here is my piece of code.
    procedure(CreateLayoutXL(libName cellName)
    ;; Generate from Source and Place as in Schematic
    newCvId = lxGenFromSource(
    CvId = dbOpenCellViewByType(libName cellName "schematic" "" "r")
    ?layLibName libName
    ?layCellName cellName
    ?layViewName "layout"
    ?initCreatePins t
    ?initCreateInstances t
    ?initCreateBoundary t
    ?initDoStacking t
    ?initDoFolding t
    ?initCreateMTM nil
    ?initGlobalNetPins t
    ?initCreatePadPins t
    ?initCreateSnapBoundary t
    ;?lxPositionMinSep n_lxPositionMinSep
    ?lxGenerateInBoundary t
    ?extractAfterGenerateAll t
    ?extractSchematic t
    ?ignoreSchematicCheck t
    ;;Auto-Routing section (source: Andrew)
    cv = dbOpenCellViewByType(libName cellName "schematic" "" "r")
    netName=cv~>nets~>name
    foreach(net netName
    geDeselectAll()
    hsmSelect(?type 'net ?name net)
    lxSelectedRoute(t)
    printf("Lib Name: %s Cell Name: %s\n" libName cellName)
    dbSave(newCvId)
    dbClose(newCvId)
    ) ;end procedure CreateLayoutXL
    The first part of the code (Generate from Source and Place as in Schematic) works in non-interactive mode. I would like to do routing part in non-interactive mode too. Is that possible? If so, could you specify the skill function?
    Dinesh
    Dinesh,
    I'm not aware of a way of doing this (other than doing it graphically using geOpen or deOpen and then running in -nograph mode with a replay file). It may be possible, but I couldn't find it (from a  fairly quick check, so I may be wrong).
    I would suggest you contact customer support where we can spend a bit more time on seeing if there's an answer or whether an enhancement request is needed.
  • DineshBabu
    Andrew,
    Thank you for the feedback. I logged in a service request regarding the same on Friday.
    Dinesh
