  3. Using inherit parameters with pcDefineInheritParam
  • Views 14525
RVERP
RVERP over 10 years ago
I have a procedure going through following steps:
  1. define a new pcell master using pcDefinePCell. This master pcell has no initial parameters defined.
  2. In this pcell, I instantiate a subMaster pcell with the dbCreateParamInst procedure. This submaster has known parameters, but I don't define them so the default values are used.
  3. I want a parameter of the submaster (x_sub) to become a parameter of the master (x_super).
  4. I use the command pcDefineInheritParam(subMaster ’x_sub ’x_super list(’x_super))
But nothing happens, my master pcell remains without paramaters. According to the manual, a new parameter should be created on the master.
It's obvious I'm doing something wrong, but I can't find out what.
