  3. How to delete only objects which are placed using script...
  • Views 15564
How to delete only objects which are placed using script?
Kinkar
Kinkar over 10 years ago
I have written a program which places metal and poly patches based on the requirement.
I want to know whether it is possible to delete only objects which are placed by using the program. Is there any way to identify the objects that are placed using the program ?
-Gopal
    Hi Gopal,
    Two easy ways you can do this:
    1. Add a user defined property on the objects you create. obj~>placedByMyProgram=t (or whatever you want). Then you can easily find them afterwards to delete
    2. (more efficient if there are lots of objects) Create a group using dbCreateGroup and then use dbAddObjectToGroup to add each object to the group. You can then find the group later using cv~>groups and easily iterate over all the members and delete them.
  • Kinkar
    Thank you for the prompt response. This is exactly what I was looking for !
    For the 1st case you mentioned, is there any way to grey-out (non-editable by user) placedByMyProgram property.
    Gopal
    Hi Gopal - I don't believe this is possible.
