  3. Return multiple values from procedure
  • Subscribers 150
  • Views 16282
ank088
ank088 over 9 years ago
Hello
I am trying to return multiple values from a procedure (actually lists).
Here is what I am hoping to achieve
procedure call  : parseFile(myfile l_dev l_Tuck l_PC_Pitch l_Nfin)
procedure(parseFile(File l_dev l_Tuck l_PC_Pitch l_Nfin)
  let(( strSplit table fpFile fpoutFile  )
     myFile = infile(File)
     while( gets( line myFile )
      strSplit = parseString( line )
         if(nth(0 strSplit)== "Device" then
            tempList=strSplit
            l_dev=remove(nth(0 tempList) tempList)
         else
             tempList=strSplit cdf=nth(1 strSplit)
             tempList=remove(nth(0 tempList) tempList)
              case(nth(0 strSplit)
                 ("Nfin"  l_Nfin=tempList )
                 ("Pitch" l_PC_Pitch=tempList)
                 ("Tuck" l_Tuck=tempList)
                 ("Finger" l_Finger=tempList)
    close(fpFile)
Contents of myfile
Device dev1 dev2 dev3 dev4
Tk single double
Nfin 2 4 8
Pitch 70n 90n
Evidently, what I trying to achieve is to pass a set of lists that are initialized in main, have them populated within the procedure and return the same back to main. The reason is I want to use this procedure as a sort of a generic procedure which can be used across scripts where the list input in "myfile" would depend
 It looks like variables passed to procedure cannot be changed within the procedure (ie Cstyle pass by reference). There probably is a simple method, but I'm not an skill expert. Hence the question
Anukul
  • Quek
    Quek over 9 years ago
    Hi Anukul
    You can return the various lists as a single list. E.g.
    list(l_dev l_Tuck l_PC_Pitch l_Nfin)
    You can then get the return values using:
    results=parseFile(File l_dev l_Tuck l_PC_Pitch l_Nfin)
    l_dev=nth(0 results)
    l_Tuck=nth(1 results)
    l_PC_Pitch=nth(2 results)
    l_Nfin=nth(3 results)
    Alternatively, you can use a table. E.g.
    procedure( myMainProc()
       let( (myTable)
          myTable=makeTable("myTable" nil)
          parseFile(myfile myTable)
          printf("%L\n" myTable["l_dev")
       ) ;let
    ) ;procedure
    procedure(parseFile(File myTable)
         myTable["l_dev"]=remove(nth(0 tempList) tempList)
         ("Nfin" myTable["l_Nfin"]=tempList )
       ) ;let
    ) ;procedure
    Best regards
    Quek
