  3. How to edit the buttons in a Form
  • Views 17179
KarthikeyanPSG
KarthikeyanPSG over 10 years ago
When we create a Form using hiCreateAppForm() functon, there are 5 buttons (OK, Cancel, Defaults, Apply and Help) being displayed at the bottom of the Form. How can we change this setting to display only 3 buttons (OK, Cancel and Help) and also rename the OK button to Run button?
    This is pretty clearly described in the documentation for hiCreateAppForm - you need to use the ?buttonLayout argument to hiCreateAppForm():
    oneField=hiCreateStringField(?name 'something ?prompt "Enter info")
    hiCreateAppForm(
      ?name 'CCFsillyExample
      ?fields list(oneField)
      ?buttonLayout '(OKCancel (Run "hiFormClose(hiGetCurrentForm())") )
    hiDisplayForm(CCFsillyExample)
    However, you must have an OK or Close button on the form - so you can have both OK and Run, but not just Run (otherwise hiFormClose/hiFormDone/hiFormFinish will fail).
  • KarthikeyanPSG
    Yeah, it works Sir. Thank you very much.
