  3. Bindkey debug with command console
  • Replies 8
  • Views 17596
JMPerdomo
JMPerdomo over 10 years ago
Hi, I remember reading in the forum a way of echo the Keyboard press into cadence console but I can't find it anymore. Can anyone help me out?
    I don't understand your question. What exactly are you trying to achieve? Please clarify with more detail...
  • skillUser
    skillUser over 10 years ago
    Hi Juan,
    I have the feeling that you are asking for something like "xev" but within Virtuoso, am I right?  There is something, I think, but I can't recall what it is called.
    Andrew does this ring any bells?
    Cheers,
    Lawrence.
  • JMPerdomo
    Sorry, let me express it better.
    What I was looking is that each time I press a keyboard key in the console appear which key was pressed.
    The point of this, Is to know if cadence is detecting the correct key when I press it.
    Thanks in advance
    If you have defined a bindkey, and go to Options->Log Filter in the CIW and turn on the "a" checkbox (Accelerated Input) you should see the bind key SKILL function echoed in the CIW for each key press. Does that do what you want, if you're simply trying to see if the bind key was recognised?
  • JMPerdomo
    Not quite, because I want to know what key is recognized by cadence.
    For example: shift+7 can be recognized as "/" in some keyboards and as "&" in another depending on the keyboard language.
    So as a debug feature, I think is useful to know which key was recognized.
    Regards
  • dmay
    dmay over 10 years ago
    The hiSetBindKey() form in Cadence 6.1.6 will show you the key as you define new bindkeys. If you press the "+" bindkey in the lower right you can define a new bindkey. Then click the key combo you want and you will see how Cadence recognizes it. This will show you if you need a "$" or a "shift-4".
    Derek
    My phone email client keeps swallowing random forum posts when there is more than one in a thread, so I missed Lawrence's reply and only noticed Derek's as I was about to reply with the same answer. This is available under Options->Bindkey in the CIW - pick the application, hit the plus button to add a bind key, and then in the key part click the key combination you want and it will show you the encoding
  • JMPerdomo
    That will work.
    Thanks all for your help.
