  3. How to get the schematic(TestBench) details associated with...
  • Views 1038
How to get the schematic(TestBench) details associated with a adexl
Manikk0501
Manikk0501 over 10 years ago
I want to get the information of the design associated with adexl session. How can I do that? Let say, I know the libname,viewname and adexl viewname. With that I want to get the testbench detail especially the testbench viewname.
Thanks and Regards,
Manikandan Kuzandhaivelu
    Hi Manikandan,
    This code will do it (the first function). It returns a list of lists, one per test in the ADE XL view (because they could have different testbenches):
    /* abGetADEXLReferences.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Nov 21, 2012
    Modified   A.D.Beckett
    By         Nov 22, 2012
    Return a list of all the references in an ADE XL view.
    Also provide a function to check if the ADE XL view
    only references testbenches from the same library.
    SCCS Info: @(#) abGetADEXLReferences.il 11/22/12.11:18:56 1.2
    *             abGetADEXLReferences(lib cell view)              *
    *  Return a list of lib/cell/view lists. Each one corresponds  *
    *     to the lib/cell/view used in the tests in the adexl      *
    *  view. It doesn't try to uniquify the list, so if the same   *
    *   testbench is used in multiple tests, it will be returned   *
    *                       multiple times.                        *
    procedure(abGetADEXLReferences(lib cell view)
        let((sess sdb references toolArgs)
            sess=axlCreateSession(strcat("refs" getCurrentTime()))
            sdb=axlSetMainSetupDBLCV(sess lib cell view)
            when(sdb
                references=
                    foreach(mapcar testName cadr(axlGetTests(sdb))
                        toolArgs=axlGetTestToolArgs(axlGetTest(sdb testName))
                        list(
                            cadr(assoc("lib" toolArgs))
                            cadr(assoc("cell" toolArgs))
                            cadr(assoc("view" toolArgs))
                axlCloseSetupDB(sdb)
            axlCloseSession(sess)
            references
    *         abAreADEXLReferencesToSameLib(lib cell view)         *
    *    Simple check on an ADE XL view to return t if all the     *
    *  testbenches come from the same library as the ADE XL view   *
    *                           itself.                            *
    procedure(abAreADEXLReferencesToSameLib(lib cell view)
        forall(lcv abGetADEXLReferences(lib cell view)
            car(lcv)==lib
    * abCheckADEXLReferencesToSameLibForLib(lib @optional verbose) *
    *       Check all the ADE XL views in the library to see       *
    *        if they have references outside this library.         *
    procedure(abCheckADEXLReferencesToSameLibForLib(lib @optional verbose)
        let((fileObj references popups (nullport outfile("/dev/null")))
            ; Suppress the convert state popups
            popups=envGetVal("asimenv" "showConvertNotifyDialog")
            envSetVal("asimenv" "showConvertNotifyDialog" 'boolean nil)
            ; attempt to swallow warnings and errors by redirecting
            ; using dynamic scoping
            let(((woport nullport) (errport nullport))
                foreach(cell ddGetObj(lib)~>cells
                    foreach(view cell~>views
                        fileObj=ddGetObj(lib cell~>name view~>name "*")
                        when(fileObj && ddMapGetFileViewType(fileObj)=="adexl"
                            when(verbose
                                printf("Checking %s/%s/%s\n" lib cell~>name
                                    view~>name)
                            references=abGetADEXLReferences(
                                lib cell~>name view~>name)
                            when(exists(lcv references car(lcv)!=lib)
                                printf("%s/%s/%s has references to %L\n"
                                    setof(lcv references car(lcv)!=lib)
            close(nullport)
            when(popups
                envSetVal("asimenv" "showConvertNotifyDialog" 'boolean t)
            t
