  3. Skill Code to move or copy layers to _nm
  • Views 2518
Mallappa T
Mallappa T over 10 years ago
Hi
 I am looking for little help to write a skill code which will copy or move layer to some _nm, that need to be like, pressing key 1 need to copy 1 grid or some _nm, prssing 2 need to copy next grid or some _nm(), if one grid equals 100nm, It need to copy when key 1 pressed it need to copy 100nm, If key 2 pressed need to copy 200nm, Please help me, Please do the needful.
Thank you Mallanna,
    Take a look in <ICinstDir>/tools/dfII/samples/local/leBindKeys.il . I'm showing the relevant lines from this file:
    ; legRpDelta : used below inside key bindings for Numeric Key Pad
    legRpDelta = 0.5
    list("<Key>KP_Equal"      "legRpDelta = 0.5")
    list("<Key>R4"            "legRpDelta = 0.5")
    list("<Key>R5"            "legRpDelta = 1.0")
    list("<Key>R6"            "legRpDelta = 2.0")
    list("Shift<Key>R7"       "leMoveCursor(-legRpDelta  legRpDelta)")
    list("Shift<Key>Up"       "leMoveCursor(          0  legRpDelta)")
    list("Shift<Key>R9"       "leMoveCursor( legRpDelta  legRpDelta)")
    list("Shift<Key>Left"     "leMoveCursor(-legRpDelta           0)")
    list("Shift<Key>Right"    "leMoveCursor( legRpDelta           0)")
    list("Shift<Key>R13"      "leMoveCursor(-legRpDelta -legRpDelta)")
    list("Shift<Key>Down"     "leMoveCursor(0           -legRpDelta)")
    list("Shift<Key>R15"      "leMoveCursor( legRpDelta -legRpDelta)")
    The idea is that there are some keys on the numerical keypad that set various values for the variable legRpDelta (you can customise these to values you want) and then the shift-arrow keys (and diagonals next to them I think - I don't have a numeric keypad on my keyboard) are set to move the cursor in a relevant direction by that amount.
    So the idea is that you start a move or copy, then hit the key to pick the delta you want, and then hit the appropriate key to move the cursor by the current delta. You can then of course move it multiple times.
    Or alternatively you can use the delta options on the F3 options form for move or copy (note the user units are typically in microns, so you'd be interested in moving by 0.1 or 0.2)
    Your request was a little imprecise and incomplete - you could move by 100nm, but in which direction? You could easily write something to do a specific move or copy using dbMoveFig or dbCopyFig - for example:
    foreach(obj geGetSelSet()
      dbCopyFig(obj obj~>cellView list(0.1:0 "R0" 1) ; Copy by 100nm to the right.
    ; legRpDelta : used below inside key bindings for Numeric Key PadlegRpDelta = 0.5list("<Key>KP_Equal"      "legRpDelta = 0.5")list("<Key>R4"            "legRpDelta = 0.5")list("<Key>R5"            "legRpDelta = 1.0")list("<Key>R6"            "legRpDelta = 2.0")list("Shift<Key>R7"       "leMoveCursor(-legRpDelta  legRpDelta)")list("Shift<Key>Up"       "leMoveCursor(          0  legRpDelta)")list("Shift<Key>R9"       "leMoveCursor( legRpDelta  legRpDelta)")list("Shift<Key>Left"     "leMoveCursor(-legRpDelta           0)")list("Shift<Key>Right"    "leMoveCursor( legRpDelta           0)")list("Shift<Key>R13"      "leMoveCursor(-legRpDelta -legRpDelta)")list("Shift<Key>Down"     "leMoveCursor(0           -legRpDelta)")list("Shift<Key>R15"      "leMoveCursor( legRpDelta -legRpDelta)")
  • Mallappa T
    I need to move it with x and y directions, i have tried your code which is " foreach(obj geGetSelSet()
    ) "  it's not working fine. i am getting error called  "*WARNING* (reader): a '(' at line 1 was still unclosed on EOF, ')' added
                        at line 4 of file /usr2/mallappa/copy.il" please look into it, Please help me.
    It's hard to imagine a clearer error message. I accidentally omitted a close parenthesis to complete the dbCopyFig call (I didn't test the code) so all you have to do is add a close parenthesis at the end (which is what the error message said). Surely you didn't need me to tell you that?
  • Mallappa T
    Dear Sir,
    Sorry for the mistake, the code is working  when i have select an layer run the script in the virtuoso, But i need the code like when i select the layer in layout view,  if i press "Key 1" it should copy the same layer one time to 100nm, if "Key 2" pressed it need to be copy 2 time the same layer bye 100nm by X and y origin. And i am not able to search example code path, please help on it.
    Thank you,
