  3. How to create #N Field is OK by skill ?
  • Subscribers 150
  • Views 15104
Charley Chen
Charley Chen over 10 years ago
Dear All,
I want to create a #11    hiCreateStringField(...) , as below :
   MyField1 = hiCreateStringField(?name   concat("strfield" 1)
                                                           ?value  sprintf(nil "%d" i)
                                                            ?prompt sprintf(nil "Field %d" i)
   MyField2 = hiCreateStringField(?name   concat("strfield" 2)
                                                           ?value  sprintf(nil "%d" 2)
                                                            ?prompt sprintf(nil "Field %d" 2)
   MyField10= hiCreateStringField(?name   concat("strfield" 10)
                                                           ?value  sprintf(nil "%d" 10)
                                                            ?prompt sprintf(nil "Field %d" 10)
But the #  field is dynamic , and it's hard to write . So i change the code ,
It has error  if the code is below
  => Error  MyField%d ^ = hiCreateStringField(?name   concat("strfield" i)
SYNTAX ERROR found at ...
for(i  0   10
   MyField%d = hiCreateStringField(?name   concat("strfield" i)
 );for
Thank you ,
Charley
    That's hardly surprising - don't know why you thought you could use %d in a variable name? It's a string formatting code in the various printf functions - you can't just use it arbitrarily elsewhere.
    You could do this (although I doubt it's the right way to do it in practice):
    set(concat('MyField i) hiCreateStringField(...))
    However, then presumably you're going to have to access this variable with a created name - which you could do with symeval(concat('MyField i)) but all you're doing here is effectively creating a poor implementation of an array. So why not either put all these fields in a list:
    for(i 0 10
      newField=hiCreateStringField(...)
      listOfFields=cons(newFields listOfFields)
    If the order matters, you could reverse the list at the end, or use tconc to construct it in the right order in the first place.
    Or you could use an array:
    declare(MyFields[11])
    for(i 0 10
      MyFields[i]=hiCreateStringField(...)
  • Charley Chen
    Andrew,
    Thank you for help.
    Charley
  • fatcat1206
    fatcat1206 over 10 years ago
    Hi Charley
    I have met the similar situation, and it might be more complicated than yours.
    As those field are dynamic, which means they can be added and removed when changing some other value in the form.
    Besides, I need to access the value and also assign the call back function for those dynamic field.
    here I just put part of my code to show how I did it:
    Best Regards
    ####### relevant code for create dynamic fields in the form #########
    procedure(createForm()
    let(
       ;create given number for group of fields
        for(Index 1 fNumGroup->value
            fGroupList = cons(createNewGroupMember(Index) fGroupList)
        );for
         ;adding the dynamic fields into the form
         foreach(group reverse(fGroupList)
            fieldList2D  = cons(list(nth(0 group) x_co:y_co     580:210  220) fieldList2D)
            y_co = y_co + 10
            fieldList2D  = cons(list(nth(1 group) x_co+10:y_co  460:25   120) fieldList2D)
            y_co = y_co + 30
            fieldList2D  = cons(list(nth(2 group) x_co+10:y_co  100:25   1) fieldList2D)
        );foreach(group)
       hiCreateAppForm(
            ?name 'testForm
            ?formTitle "Test  Form"
            ?fields fieldList2D
            ?initialSize (1000:1200)
            ;?dialogStyle 'modal
            ?buttonLayout 'OKCancelDef
            );hiCreateAppForm
    );let
    );proc(createForm()
    procedure(createNewGroupMember(Index)
    let(
        newGroup                    ;list of added group, which contains several fields
    );local variable
        newGroup =list( hiCreateFrameField(
                            ?name stringToSymbol(strcat("fFrame_" sprintf(nil "%d" Index)))
                            ?labelText strcat("Group" sprintf(nil "%d" Index))
                            ?enabled t
                            ?invisible nil
                        );createFrame
                        hiCreateRadioField(
                            ?name stringToSymbol(strcat("fRadio_" sprintf(nil "%d" Index)))
                            ?prompt "Key Word Type"
                            ?choices list("choice1" "choice2" "choice3")
                            ?value "choice1"
                            ?defValue "choice1"
                            ?callback list(strcat("printSelPins(testForm" sprintf(nil "%d" Index) ")"))
                            ?enabled t
                            ?invisible nil
                        );createRadioField
                            ?name stringToSymbol(strcat("fString_" sprintf(nil "%d" Index)))
                            ?prompt "Key Words"
                            ?value ""
                            ?callback strcat("printSelPins(testForm" sprintf(nil "%d" Index) ")")
                            ?enabled t
                            ?invisible nil
                        );createStringField
                    );list
        newGroup
    );let
    );proc
    procedure(SprintSelPins(form Index)
    let(
        UDKeyWords          ;list of user defined key words
    );local variable
        ;get the value from the dynamic field
        UDKeyWords = parseString(get(form stringToSymbol(strcat("fString_" sprintf(nil "%d" Index))))->value)
    );let
    );prog
