  3. creating a file name to save s-parameters based on design...
  • Views 14647
creating a file name to save s-parameters based on design variables
Joost
Joost over 10 years ago
To save an s-parameter file I can enter a filename in the options form for the sp-analysis. But this file name seems to be fixed. When doing a parametric sweep (2 levels or more deep) each sp-analysis overwrites the previous filename. How can I contruct a filename based on the parameters which are swept? Suppose I sweep R and C the filename should be something sp_var("C")_var("R").
Thanks.
