  3. Unable to check and save schematic using skill code
  • Subscribers 150
  • Views 17596
analogcad2
analogcad2 over 10 years ago
I have below skill code (it's just a part of big skill I'm writing):
if(checkNsaveFlag==1 then
         if(ddGetObj(cv~>libName cv~>cellName cv~>viewName "*")~>isWritable then
                   printf("Trying to check and save schematic:%L/%L/%L\n" cv~>libName cv~>cellName cv~>viewName)
                  schCheck(cv)
                  dbSave(cv)
                  dbClose(cv)
        else
                 dbClose(cv)
                 printf("Cell view is not writable, make sure you have checked out:%L/%L/%L\n" cv~>libName cv~>cellName cv~>viewName)
       );if
);if
However I see below error in CIW when I run this code:
Trying to check and save schematic:top_01/psu_ref/schematic
*Error* (SCH-1007): The current command cannot complete as the cellview is read-only. Select File - Make Editable to make the cellview writable or, alternatively, call dbReopen to change to append or write mode.
However I have write permission on all the files inside this schematic directory in linux.
Plus if I don't have write permission then if should fail: if(ddGetObj(cv~>libName cv~>cellName cv~>viewName "*")~>isWritable then
and it should print the statement in else part.  Any ideas what is wrong with code?
Sandeep
  • Quek
    Quek over 10 years ago
    Hi Sandeep
    Does adding dbReopen(cv "a") before schCheck resolve the problem?
    Best regards
    Quek
