  3. Compare words from list
  • Subscribers 150
  • Views 15228
Gaga
Gaga over 10 years ago
I'm new in Skill programming and trying different excercises. I try to read file, and count the rows, words on the single row, finding a unique words and checking how many times the unique word exists in the row..
inPort = infile( "filename" )
countRows = 0
when( inPort
while( str = lineread( inPort )
a = length( str )
++countRows
close( inPort )
countRows is for number of the rows, and "a" gives me the number of words.. I found procedures for that how many times the unique word exists.. but I don't know how to use it correctly..
procedure( trCountValues( aList )
let( ( ( countTable makeTable( "ValueTable" 0 ) ) )
foreach( element aList
countTable[ element ] = countTable[ element ] + 1
) ; foreach
foreach( key countTable
printf( " %L occurred %d times.\n"
key countTable[ key ] )
) ; foreach
tableToList( countTable ) ;; convert to assoc list
) ; let
) ; procedure
I'll be thankful on any help!
  • Quek
    Quek over 10 years ago
    Hi Gaga
    You can do it as follows:
    procedure( CCSreadAndCount(file uniqueWord)
       let( (inPort lineCount wordCount uniqueCount inLine inLineList
         reducedList)
          inPort=infile(file)
          unless( inPort error("Cannot open file %s" file))
          lineCount=1
          wordCount=0
          uniqueCount=0
          while( gets(inLine inPort)
             ; To keep things simple, we are assuming that the line really consists of just words and no brackets, commas, etc
             inLineList=parseString(inLine " \t\n")
             wordCount=length(inLineList)
             lineCount++
             reducedList=remove(uniqueWord inLineList)
             uniqueList=length(inLineList)-length(reducedList)
             printf("There are %d \"%s\" and total %d words in line %s"
               uniqueCount uniqueWord wordCount inline)
         ) ;while
         close(inPort)
         printf("There are %d lines\n" lineCount)
       ) ;let
    ) ;procedure
    The above procedure can be used as follows:
    a. Save the codes in a file named "getdata.il"
    b. Load the file in CIW:
    load "./getdata.il"
    c. Execute the procedure:
    CCSreadAndCount("/your-path/yourfile" "myUniqueWord")
    Best regards
    Quek
  • Gaga
    Thank you very much, Quek!
