  3. Refresh/update/re-create form problem
  • Views 4187
KokoLiu
KokoLiu over 10 years ago
I am planning to create a form that I would able to either refresh or update the new time I call it or it will able to remove the form and create again. I research for awhile and I was trying to do hiFormDone to remove and recreate the form. But I got into the following warning. And I am not sure how to remove the form and re-create it. Or is it easier to update the report field? If so then how can I regenerate the report field?
Thank you very much.
*WARNING* hiDeleteForm: Cannot delete a form that is mapped or from within the form's callback (WindowForm)
*WARNING* hiCreateAppForm: Could not delete already created form WindowForm
procedure(clWindowForm()
let((windowField)
if(hiIsFormDisplayed(WindowForm) then
hiFormDone(WindowForm)
windowField = hiCreateReportField(
?name 'window
?selectMode 'single
?headers '(("Library" 120 'left 'string t)
("cell" 300 'left 'string t)
("view" 120 'left 'string t)
("" 0 'left))
?choices clwindowList()
?sort '(2 nil)
WindowForm = hiCreateAppForm(
?name 'WindowForm
?formTitle "Windows"
?fields list(
list(windowField 0:0 600:500 300)
?buttonLayout '(OKCancel (Left "clWindowResize(\"L\")") (Right "clWindowResize(\"R\")") (Close "clWindowResize(\"Close\")"))
hiDisplayForm(WindowForm)
    The problem is that the form doesn't get unmapped immediately, and so it's still mapped whilst the form is being recreated. One way around this is to use hiEnqueueCmd(). I also put an extra check that the form variable is bound so that it works the first time around:
    procedure(clCreateAndDisplayForm()
      let((windowField)
          ?name 'window
          ?selectMode 'single
            ("" 0 'left))
          ?sort '(2 nil)
          ?name 'WindowForm
          ?fields list(
      if(boundp('WindowForm) && hiIsFormDisplayed(WindowForm) then
      hiEnqueueCmd("clCreateAndDisplayForm()")
  • KokoLiu
    Thank you very much. That works.
