  3. Radio Field and String Field doubts
  • Views 14844
netbug
netbug over 10 years ago
I am trying to do a simple script, which should create a form with some text boxes and radio buttons.
Given the code in the end of this post I would like to add the following functionalities:
1 - If myOptionBtn is set to "Yes" send a message to the screen, otherwise do nothing.
2 - If I am refering to the value of a radio field, can I use something like:
if ((formName->radioName->value)=="t") then
hiGetAttention()
warn("some text"))
3 - i would like to pop a window for the user to select a directory and store that into a variable or text file.
I did my code based on an example in Cadence Documentation. Below is what I have done so far.
procedure(formSettings()
; Create the top label
myLabel=hiCreateLabel(
?name 'myLabelText
?labelText "Settings"
?justification 'center
; Create the textbox Label
myString=hiCreateStringField(
?name 'myTextBox
?prompt "Path: "
?value "Insert path to your images here !"
?defValue "~/Desktop/"
;option Buttons
myOptionBtn = hiCreateRadioField(
?name 'optionbtn
?prompt "Generate all the documents for me"
?defValue "No"
?choices list("Yes" "No")
if( boundp('formSettings) then ; If the form already exists do nothing
formSettings
else ; If the form doesn't exist then create it
hiCreateAppForm(
?name 'settingsForm
?formTitle "settings"
?callback "";
?fields list(myLabel myString myOptionBtn)
status = hiDisplayForm(settingsForm)
Thanks in advance,
José
