  3. Snapshot functionality in Cadence Skill
  • Views 16721
Shubhy
Shubhy over 10 years ago
I'm building a skill code which works like a snapshot.
There would be some objects(metals, poly, od etc. ) kept on the top level of the cell.
And the user would give a list of bBoxes.
For each bBox acting as a frame of the camera , whatever objects are kept inside that specific area should be copied in a new cell.
By the word specific I mean if a metal elongates outside a bBox then only that part should be copied which is inside the bBox.
    This sounds like you want to use the yank & paste capabilities in the layout editor. The SKILL functions for these are leYankFigs() and lePasteFigs().
  • Shubhy
    Thanks Andrew,
    I was able to figure it out of Yank & paste commands. But there's another issue occurring now.
    If a leafcell / via instance also gets inscribed in the given point array then even that is yanked and pasted. Is there any other way by which we could avoid the instances and only concentrate on the physical layers on top ( like the metals / polys etc. )
    Regards
    Shubham
    Hi Shubham,
    A couple of approaches you could take:
    1. Use dbGetOverlaps() with 0 as the stop level to identify all the shapes that are within the bBox you are interested. This will include shapes that straddle the bBox too. Iterate through the results (may have to check whether some are instances by looking at the ~>objType) and then use dbCopyFig to copy them to your second cellView. Then in the second cellView, do a yank in the area you wanted, delete all the shapes present, and then paste back into the same cellView.
    2. Create a rectangle in the source cellView with the bBox you want (on some dummy layer). Then iterate through each of the cv~>lpps present in the cellView, and do a dbLayerAnd of each of these sets of shapes with the dummy rectangle, with the output on the same lpp into the new cvId. Once done, delete the dummy rectangle
    I've not actually tried either of these, but I think they should work. I am assuming that dbLayerAnd into a different cellView from the source shapes will work - if it doesn't, you may have to write them into the source cellView and then call dbMoveFig to move them into the new cellView.
