  3. Crop functionality in SKILL ?
  • Views 15397
Shubhy
Shubhy over 10 years ago
A leChopShape function chops a shape based on the points given to it. The left out part is preserved.
But does there exist a function which can chop the rest of the shape except the part inscribed inside a given bBox / set of points ?
Does SKILL have a crop function or lets say an inverse chop function ?
    I suspect you're asking this because of your other post. If so, see my answer there which may avoid the need for you to do this.
    There isn't really a function to do this - you could probably construct one with a bit of thought, but I suspect you may not need it if it's related to your other post.
    Kind Regards,
