  3. ADE-XL select tests
  • Views 15131
ADE-XL select tests
netbug
netbug over 10 years ago
Dear all,
I have an ADE-XL session with multiple tests set. I would like to be able to select the in the results tab one at a time.
When enabling "Accelerated Input", I can see that the command used is _axlTestFilterChanged(axlOutputsForm1->axlOutputsWidget1 "'(\"Test1\")").
Instead of referring by name I would like a way to identify each element of the dropdown menu by an ID.
I tried help from virtuoso and finder but cannot find the function _axlTestFilterChanged anywhere.
José
    Hi José,
    Functions used for recording interactive interactions that get recorded in the CDS.log are often private functions because they're only ever intended to be used for replay, not for procedural use.
    There is no public API to do what you want. You'll need to contact customer support to request this as an enhancement.
  • netbug
    Thanks a lot for your reply.
    Cheers,
    José
