  3. How to edit NMOS/PMOS W/L of an inverter layout using SKILL...
  • Subscribers 148
  • Views 3094
How to edit NMOS/PMOS W/L of an inverter layout using SKILL code
skvishvakarma
skvishvakarma over 10 years ago
Hi
I am using Virtuoso IC6.1.6.
I would like to parameterize an inverter layout for automatic layout design from it's schematic.
Therefore I am trying to edit of NMOS/PMOS W/L of an inverter using skill code in following way:
1. I am using instances (NMOS/PMOS pcells) from technology file (ex. umc, tsmc or gpdk) and made a inverter layout.
2. I want to edit 'width/length' of NMOS/PMOS using skill code
Please let me know how can I write a skill code for the above case.
 I would be glad if you may provide some examples or test case.
Looking forward to see a quick response.
Thanks.
  • skillUser
    skillUser over 10 years ago
    I would start by looking at the sample ROD PCells in your installation, for example <instRoot>/tools/dfII/samples/ROD/rodPcells/components/inv/inv.il which in turn instantiates/uses spcnmos and spcpmos devices.  There is an "install" directory that you can use to set up and load the devices so you can take a look and play with what's provided.  There is a fair amount of code here though, so you may need to reduce it down to a simpler version.
    Hopefully this can help to get you started?
    Best regards,
    Lawrence.
  • skvishvakarma
    Thanks.
    I will start with this.
