  3. defining corners and run analysis from ocean
  • Subscribers 150
  • Views 14571
archive over 18 years ago
I'm trying to define my corners and analysis directly in the ocean file as I don't see the reason to use a pcf or a dcf file. The problem I have is to define the simulation that the cornerRun() is supposed to perform. Current result is just like running the cornerTool from AWD when you forget to define an ananlysis: The design i read in, all warnings and notices are printed, but no analysis is run.
What I have is so far:
... more ocean/skill ...
corner_analysis = t
(when corner_analysis
... define tech, corners and variables ...
analysis('tran ?stop 1n)
cornerRun()
I've been through debugging the tech, corners and variables setting so I am quite sure that it is possible to do this self-contently inside an ocean script, but cornerRun() doesn't seem to work like monteRun() where I define the analysis just before the call to monteRun() and everything works just fine. Documentation on the cor* functions does not give real help as I am probably "exhausting" the use of corner simulations.
If anybody has an idea, I would be very happy as I hope to do a final verification in batch only where the simulation file is self-content.
Svenn
Originally posted in cdnusers.org by svenn
