  3. How to setup SVS comparison flow?
  • Views 18101
Kodela
Kodela over 10 years ago
Hello Experts,
I want to compare two schematics using Virtuoso Schematic Editor : PVS -> Run SVS:
- same/different library but different cells
- same library, same cell but different view names
Appreciate a step-by-step approach.
Thanks & Regards,
Ravi
    Andrew Beckett over 10 years ago +1
    Ravi, This is covered in the PVS User Guide (in a step-by-step way), so I assume you didn't look at that. You can either run: <PVSinstDir>/tools/bin/cdnshelp to access this, or just open <PVSinstDir…
    Ravi,
    to access this, or just open <PVSinstDir>/doc/pvsuser/pvsuser.pdf in a PDF reader. There's a whole chapter on SVS.
