  3. Add Toolbar in CIW window?
  • Subscribers 150
  • Views 16427
Chiranshu
Chiranshu over 10 years ago
I want to add Toolbar in CIW window,in which i will give string eg :- "/proj/projects/workarea/skill_work/assignment.il" and it will automatically load that file. I want that because i dont want to type again loadi"...." command
  • drp2
    drp2 over 10 years ago
    Inside a file (I call mine ciw.il) put:
    test = hiCreateMenuItem(
            ?name   'assignments
            ?itemText       "assignments"
            ?callback       "load(\"/proj/projects/workarea/skill_work/assignment.il\")"
    hiCreatePulldownMenu(
           'ciw1
            "MyStuff" list( assignments )
    hiInsertBannerMenu(hiGetCIWindow() ciw1 7)
    in your cdsinit (or where you put things to automatically load) add:
    load("/proj/projects/workarea/skill_work/ciw.il")
    When start cadence you should have a MyStuff menu at the 7th position.  The 7th position is my default last spot on the CIW before help menu, yours may vary.
    Alternatively, you can just assign a bindkey and load it with that:
    hiSetBindKey("Layout" "<Key>F6" "load(\"/proj/projects/workarea/skill_work/assignment.il\")")
    Hope this helps,
    Dan
    How about this (to show how to create toolbars - this is a very simple example)?
    /* CCFloadFile.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Apr 27, 2016
    Modified
    By
    Example of creating a toolbar in the CIW.
    Call:
    CCFplaceLoadFileToolbar()
    to add it to the top of the CIW.
    SCCS Info: @(#) CCFloadFile.il 04/27/16.11:33:18 1.1
    procedure(CCFcreateLoadFileToolbar()
      let((fileName load)
        fileName=hiCreateToolbarTypein(
          ?name 'fileName
          ?prompt "File"
          ?width 400
          ; doesn't seem to work if just hit return...
          ?CBOnEnter "CCFloadFileFromToolbar()"
        load=hiCreateAction(
          ?name 'load
          ?iconText "Load"
          ?callback "CCFloadFileFromToolbar()"
        CCFloadToolbar=hiCreateToolbar(
          ?name 'CCFloadToolbar
          ?title "Load SKILL"
          ?items list(fileName load)
    procedure(CCFloadFileFromToolbar()
      loadi(CCFloadToolbar->fileName->value)
    procedure(CCFplaceLoadFileToolbar(@optional (win hiGetCIWindow()))
      unless(boundp('CCFloadToolbar)
      hiPlaceToolbar(win CCFloadToolbar 'top)
