  3. linread command error out when trying to read in complex...
  • Views 16599
linread command error out when trying to read in complex lines
mlea
mlea over 10 years ago
Im using lineread command to read in from an input port .
Im reading the verilog si log file m which contain line such as ( start with):
/p/virtuoso/blabla
and also:
*/sdf/bla
the command lineread error out with syntax error, maybe because it is intended to parse things more than read in complex list ( which is what the  line is)
i tried other commands as well : read , linereadstring.  also sprintf("" %L lineread(line)) doesnt help..
what can be done is such cases?
thx
meny
    Hi Meny,
    Use gets(). lineread and the other functions you tried are using the SKILL parser intentionally - things that don't conform to SKILL syntax should not be read with that family of functions.
  • mlea
    Andrew,
    getc will read only one char at a time... i guess i will have to build each line by looking the "\n" char.
    thx
    meny
    Hi Meny,
    I didn't suggest getc(). I suggested gets(). That reads a line at a time.
  • mlea
    sorry. its my mistake - I was reading on gets and getc on the skill finder and got mix in my reply .. any how i solved this with simple two line perl script. gets command do the work... thx
