  3. update progress bar in real time
  • Views 17260
mlea
mlea over 10 years ago
im using ipcBeginProcess commands to launch two external process, and trying to update a progress bar :
the first process run generate  verilog netlist .
the second one phrase the log file of the generation process and update a progress bar accordingly.
I have two problem
1. the progress bar got freeze out while the first process is running.
2. the first process exit code become alive only if i use ipcwait(first_process)
this is what i do :
procedure(simTerm(cid1 exit)
printf("Simulator expired with exit status = %L\n" exit)
exitCode=exit
procedure(handler(cid1 data)
printf("\n Date:%s\n" data)
procedure( simErr(cid1 err)
printf("Error %L Msg: %s\n" cid1 err)
procedure(handler2(cid2 data)
myvar=data;
printf("\n%s\n" data)
exitCode=nil
myvar=nil
cid1=ipcBeginProcess(strcat( pwd "/libFlow/" libname "/" cellname "/verilog/" "si.csh") "" "handler" "simErr" "simTerm" )
ipcSleep(1)
cid2=ipcBeginProcess(strcat( pwd "/readSiLogFile.pl") "" "handler2")
ipcSleep(1)
;; now launching the progress  bar
hiDisplayProgressBox(
?name 'myBar
?banner "verilog progress"
?text "Run completed.. "
?callback "printf(\"Done\n\")"
?totalSteps 10
?autoClose t
;; now running a while loop to check when exit status  cid1
while(!exitCode
  while( myvar
do something - update progress bar -hihiSetProgressAndText....
this make the progress bar freeze, and the while loop is endless( the exitCode variable never get "alive").
i guess this is because SKILL dont see the any exitCode/myvar variable  while its inside the loop, even though the cid1 process was launched
with communication channels.
but if I do :
while(!exitCode
  ipcWait(cid1)
;;and  only now  update the progress bar with hihiSetProgressAndText(myBar 4 "running")
this loop run and terminate but :
1. virtuoso is freeze as long the while loop running
2. the progress bar is freeze and blank out
3. it is impossible to update the progress bar in real time , only after the verilog netlist process was terminated.
i couldn't find any real example/explanation on the progress bar. should it be execute with ipcbeginProcess?
thx
meny
  • mlea
    i solved this issue by modify the code to :
    while(ipcIsAliveProcess(cid1) && !exitCode
    ipcSleep(2)
    if(!rexMatchp("Running netlisting" myvar ) then
    hiSetProgressAndText(myBar 2 "Running netlisting")
    printf("stage1\n")
    ipcSleep(1)
    if(!rexMatchp("Initializing from libInit.il for library tsmcN28" myvar ) then
    hiSetProgressAndText(myBar 5 "Initialize libInit.il")
    printf("stage2\n")
    ipcSleep(1)
    if(!rexMatchp("CELL NAME VIEW NAME NOTE" myvar ) then
    hiSetProgressAndText(myBar 7 "Grouping..")
    printf("stage3\n")
    ipcSleep(1)
    if(!rexMatchp("End netlisting" myvar ) then
    hiSetProgressAndText(myBar 9 "Finish")
    printf("stage3\n")
    ipcKillProcess(cid1)
    ipcSleep(1)
    Hi Meny,
    Glad you've got it working, but I don't think this is the right way to do this. You are using a polling model which is still holding up the Virtuoso UI except is checking between ipcSleep calls.
    Better would be to use a fully-asynchronous approach and get your data handler / exit handler to update the progress bar. That way there's no need for anything to wait or sleep at all, and Virtuoso would remain responsive.
