  3. Hooks in to ADE-XL spec summary and datasheet creation
  • Subscribers 152
  • Views 15911
danmc91
danmc91 over 10 years ago
Is there a way in skill to hook into the ADE-XL spec summary creation and also datasheet creation?
I'm looking for a way to export both of these to LaTeX instead of .csv for the spec summary and xml for the datasheet.
Barring a direct way, I can't even seem to find an API to let me generate the spec summary CSV file via skill.  Also I noticed that what I get in the CSV file is not the same as what I get on the screen. In particular, the model files on the screen are semi-helpful (but could be better):
CornerModels=high,low,typ
but the corner name I had used in the corner setup is not listed.  Also those sections are of course different for the different model files.  In the CSV file I have stuff like:
CornerModels=(file1.scs,<unspecified section>),(file2,<unspecified section>),(res.scs,high),(cap.scs,low).....
which is a pain because I will have to convert the big model lists to the corner name.
Yet another mystery is that I can't seem how to tell via skill if a model file is included in a corner.
   corners = axlGetCorners( sdb )
   foreach( corner  cadr( corners )
       printf( "Corner:  %L\n", corner )
       cid = axlGetCorner( sdb, corner )
       models = axlGetModels( cid )
       foreach( model cadr( models )
          mid = axlGetModel( cid, model )
          section = axlGetModelSection( mid )
          printf( "\t(%L,%L)\n",model, section )
          ;; HOW TO TELL IF A MODEL IS INCLUDED IN THIS CORNER?
          ;; THE ATTACHED SKILL CODE LISTS EVEN DISABLED MODELS
      ) ;; foreach model
   ) ;; foreach corner
One thing which would be great is a way to define skill code for the formatting in the output files.  For example the .csv export of the spec summary.  If I could define skill code to control this, perhaps I could write out LaTeX directly instead of trying to convert the csv and xml files over.  Also I'd maybe have a chance at converting long model file strings into something useful (like corner names).
  • fatcat1206
    fatcat1206 over 10 years ago
    Hi, Dan Mcmahill
    Below is a procedure I made to get the Corner Setup in the ADE-XL.
    I hope it would be helpful to you.
    The code in red, is used to check whether the model file is selected/enabled in the corner.
    ; PROCEDURE NAME:  printTestCorInfo
    ; ABSTRACT :
    ;   print the enabled corner info of the corresponding test, except the norminal corner
    ; AGURMENTS :
    ;   myFileID                output file ID
    ;   testSession             session object of the corresponding test
    ;   sdbh                    adexl session database handle
    ;   enCor                   enabled corner for the corresponding test
    ; RETURN VALUE :
    ;   none
    ; UPDATES :
    ;   date:   July 27 2015    Prepared: Yi WANG
    procedure(printTestCorInfo(myFileID testSession sdbh enCor test)
    let(
        cornerHd    ;handle of the corner
        cVarList    ;list of variables used in corner
        cVarVal        ;value of the variable
        modelList    ;list of the used model
        enVarList    ;list of enabled variable
        tVarList    ;list of test variables
        gVarList    ;list of global variables
        gVarHd        ;handle of global variable
        tVarName    ;name of the test variable
        modelHd    ;handle of the model
        modelSecList    ;list of sections for the model
        modelSel    ;change to "t", if one model file has been selected
        ;get the corner handle, base on the corner name
        cornerHd = axlGetCorner(sdbh enCor)
        ;get the model list which is used in the corner
        modelList = cadr(axlGetModels(cornerHd))
        ;get the variables which are used in the corner
        cVarList = cadr(axlGetVars(cornerHd))
        ;set the initial value of the list which contains the used variable.
        enVarList = nil
        ;set the initial value of the marker to be nil, which indicate there is no model has been used in the corner.
        modelSel = nil
        ;check whether one of the model file has been selected
        foreach(modelFile modelList
            modelHd = axlGetModel(cornerHd modelFile)
            modelSel = or(modelSel axlGetEnabled(modelHd))
        );foreach
        if(modelSel then ; if one of the model file has been used in the corner, then print then enalbed one
            foreach(modelFile modelList ;travel through the model file list
                when(axlGetEnabled(modelHd)  ;when the model file is specified in the corner setup
                    modelSecList = parseString(axlGetModelSection(modelHd) "\"") ;get and parse the model section list.
                    fprintf(myFileID "\t Model path:   \t%L (C)\n" axlGetModelFile(modelHd)); print out the model file
                    fprintf(myFileID "\t Model sections:    \t")
                    foreach(modelSec modelSecList
                        fprintf(myFileID "%s " modelSec); print out the model file section.
                    );foreach
                    fprintf(myFileID "\n")
                );when
            );foreach
        else ; if none of the model file has been selected in the corner, print the setup in the ADEL.
            modelList = asiGetModelLibSelectionList( testSession ); get the model file used in the design
            foreach(modelFile modelList ;travel through the model list.
                modelSecList = cdr(modelFile)   ;get the model section list
                fprintf(myFileID "\t Model path:   \t%L (L)\n" car(modelFile)); print out the model file
                when(car(modelSecList)!= "" ; if there is model section has been defined.
                    fprintf(myFileID "\t Model sections are \t")
                        fprintf(myFileID "%s \n" modelSec); print out the model file
                    );foreach
                );when
            );foreach
        );if
        ;print the variable defined in corners
        foreach(cVar cVarList   ;travel the corner variable list
            gVarHd = axlGetVar(cornerHd cVar)   ;get the handle of the variable by name
            cVarVal = axlGetVarValue(gVarHd)    ;get the value of the variable.
            when(cVar == "temperature" cVar="temp")     ;change "temperature" to "temp"
            fprintf(myFileID "\t %s:\t\t%s\t(C)\n" cVar cVarVal); print out the enabled test varirable
            enVarList =cons(cVar enVarList) ;add the variable to the "enVarList"
        );foreach
        ;print the extra variable defined in globale variables
        gVarList = cadr(axlGetVars(sdbh))   ;get the global variable list
        unless(axlGetAllVarsDisabled(sdbh)  ;if global variables are enabled.
            foreach(gVar gVarList   ;travel through the global list
                gVarHd = axlGetVar(sdbh gVar)   ;get the handle
                when(axlGetEnabled(gVarHd) && !member(gVar enVarList) && axlGetEnabledGlobalVarPerTest(sdbh gVar test);when the variable is enabled and enabled for the test, and has not been defined in the corner.
                    fprintf(myFileID "\t %s:\t\t%s\t(G)\n" gVar axlGetVarValue(gVarHd)); print out the enabled global variable
                    enVarList = cons(gVar enVarList)    ;add the variable into the "enVarList"
                );when
            );forearch
        );unless
        ;print the extra extra variable defined in test
        tVarList = asiGetDesignVarList(testSession) ;get the variable list defined in the design
        foreach(tVar tVarList ;travel through the design variable list.
            tVarName = car(tVar)    ; the design variable list always contain varialbe pairs (name value)
            unless(member(tVarName enVarList)    ;when the variable is not defined in the corner and global.
                fprintf(myFileID "\t %s:\t\t%s\t(L)\n" tVarName cadr(tVar)); print out the enabled test varirable
            );unless
        );foreach
    );let
    );procedure printTestCorInfo
    Best Regards
    Yi
