  3. Unable to to add pull-down menu to the schematic window
  • Subscribers 150
  • Views 17101
Alex Stepanov
Alex Stepanov over 10 years ago
I am trying to add pull-down menu to the schematic window.
procedure( CCSCreateSchematicMyToolsPulldownMenu()
let(()
if( boundp( 'CCSSchMyToolsMenu )
then CCSSchMyToolsMenu
else
hiCreatePulldownMenu(
'CCSSchMyToolsMenu ; Item name
"My Tools" ; Item text
list(
hiCreateMenuItem(
?name 'GetListOfSelectedPins
?itemText "Print list of selected pins"
?callback "GetListOfSelectedPins()"
);hiCreateMenuItem
hiCreateMenuItem(
?name 'CreateAMSNetlist
?itemText "Create AMS netlist"
?callback "CreateAmsNetlistFromCurrentCell()"
);hiCreateMenuItem
);list
);hiCreatePulldownMenu
);if
) ; let
) ; CCSSchematicMenuTrigger
procedure( CCSSchematicMenuTrigger(@optional (triggerArgs getCurrentWindow()))
let(( banner window )
; Determine if the argument is a trigger argument list or a window.
if( typep( triggerArgs ) == 'list then
window = triggerArgs->window
else
banner=hiGetBannerMenus( window )
unless( member( 'CCSSchMyToolsMenu banner )
printf("Creating custom menu in window %L\n" window)
hiInsertBannerMenu( window CCSSchMyToolsMenu length(banner)-3 )
);unless
);let
) ; procedure
deRegUserTriggers("schematic" nil nil 'CCSSchematicMenuTrigger)
deRegUserTriggers("schematicXL" nil nil 'CCSSchematicMenuTrigger)
If i am opening schematic view directly or if i am opening schematic inside ADE-XL and running CCSSchematicMenuTrigger procedure manually menu is added. But when I am opening schematic from ADE-XL (open design in tab) the menu is not added. What am I doing wrong?
Thank you.
    You just need to register it for two additional apps:
    deRegUserTriggers("analogArtist-schematic" nil nil 'CCSSchematicMenuTrigger)
    deRegUserTriggers("adexl-schematic" nil nil 'CCSSchematicMenuTrigger)
    Note however that you're really doing this the wrong way - I've seen things break when people use the post-install trigger for installing menus. The right way is really to define a menu trigger which returns a list of the pulldown menus you wish to add, and then let the Design Editor ("de") take care of it. This is done using the 3rd (rather than 4th) argument of deRegUserTriggers - and your trigger function should not do hiInstallBannerMenu().
    The function could be as simple as:
    procedure(CCSbannerMenuTrigger(args)
      list(CCSCreateSchematicMyToolsPulldownMenu())
    then:
    deRegUserTriggers("schematic" nil 'CCSbannerMenu)
    deRegUserTriggers("schematicXL" nil 'CCSbannerMenu)
    deRegUserTriggers("analogArtist-schematic" nil 'CCSbannerMenu)
    deRegUserTriggers("adexl-schematic" nil 'CCSbannerMenu)
    something like that (I didn't test it).
  • Alex Stepanov
    I changed to menu trigger and it works. Thank you.
  • fatcat1206
    fatcat1206 over 9 years ago
    Hi Andrew
    I have used your method, it's quite easy to implement.
    Much clear than the documentation.
    One extra question about the "deRegUserTriggers("schematic" nil 'CCSbannerMenu)"
    Is there any way to check whether "ÇCSbannerMenu" has been registered?
    As if I run the "deRegUserTriggers("schematic" nil 'CCSbannerMenu)" for second time, a warning message pops up.
    I just want to add some conditional statement to avoid double registering.
    Best Regards
    Yi
    Hi Yi,
    member('CCSbannerMenu deGetAppInfo("schematic")->userMenuTrigList)
    will return non-nil if it's been defined already. You can check the user app trigger and user post-install trigger by using a similar expression but with ->_userAppTrigList or ->_userPostInstallTrigList . Don't ask me why those have underscores at the beginning but the menu trigger doesn't. Some strange historical decision that was made 15 years ago, I expect...
  • fatcat1206
    Hi Andrew
    Happy new year :)
    Thank you for the info.
    It's very helpful.
    Best Regards
    Yi
