  3. Using LayoutXL in SKILL without Window/GUI
  • Views 4459
mp133786
mp133786 over 10 years ago
Hi.  I am using version IC6.1.6.
Somewhat new at SKILL code.  We open Schematic view.  From that Schematic window, we do "Launch -> Layout XL"  and open layout.
From that Layout XL window, we run some SKILL procedure thru small GUI form we created.
That procedure sets layout view pointer as:
cvId_layout = hiGetCurrentWindow()~>cellView
I want to achieve same functionality without any GUI/window.  How do I achieve this?
I am trying to run that skill procedure in "batch" mode with something like:
virtuoso -nograph -log myTest.log -replay myTest.il
In my SKILL procedure I replaced cvId_layout as below, but everything else remains same.
cvId_layout = dbOpenCellViewByType("myLib" "myCell" "layout" "" "a")
and operate on cvId_layout object, but result is different when running with and without GUI/window.
Any help or suggestion on starting layoutXL without GUI/window? Thank you.
    It might have helped if you'd explained what your code does? Without knowing what it's doing, it's hard to know.
    There are various Virtuoso Layout Suite XL commands that are available in SKILL; run "cdsFinder" and search for "lx" with the "Match beginning" checkbox enabled.
    One that might be important is lxRunCmdInVXL
  • mp133786
    Thank you Andrew. Running lxRunCmdInVXL(cvId_layout 'myProcedureName nil) worked fine. Our procedure does routing. Now, is there a something similar to "lceGetIncompleteNets()" that reports number of shorts? I tried looking "lceGet" in cdsFinder but found nothing. Thank you.
    It works for me (I picked the base IC616 release as I didn't know which version you were using):
  • mp133786
    Hi Andrew, "lceGetIncompleteNets()" works for me too. I was asking if there's something similar to get shorts. IE: ""lceGetShortedNets()" type command. Thank you.
    This doesn't exist, and I haven't seen anyone requesting it either. I did wonder about processing the markers to look for the information - it's feasible - but you probably have to build in two many assumptions about precisely what the marker is called.
    So you should contact customer support to request an enhancement for such an API.
  • mp133786
    Yes, I started using markers to find shorted nets as well as open (disconnected) nets in my procedure. Thank you..
