  3. how to parse/print a variable number of arguments
  • Views 1934
NoelCFC
NoelCFC over 10 years ago
I have a list with the names of the signals I want to parse to a function and also to print to a file (using fprintf). My problem is that the number of signals is not fixed; it can be only 3 or it could be 18. Any suggestions on how I could implement such function and also how to print when I don't know the number of arguments to print?
Thanks very much in advance.
Best regards,
    There are numerous ways you could do this:
    procedure(CCFprintListToFile(fileName signals)
      let((port)
        port=outfile(fileName)
        foreach(signal signals
          fprintf(port "%s\n" signal)
        close(port)
    Or:
      let((port)
        fprintf(port "%s\n" buildString(signals "\n")) ; could use "," as second arg to buildString if you want them comma separated
        close(port)
    Then:
    signalList='("a" "b" "c" "d" "e" "f")
    CCFprintListToFile("dump.txt" signalList)
    Note I didn't test either of the above - there are numerous other ways you could do it too - but this just strikes me as being an easy iteration of a list problem, or using a function such as buildString to covert a list of strings into a single string with a separator.
  • NoelCFC
    Hi, Andrew.
    Thanks for the reply. I'll try that.
    Best regards,
