  3. Skill mode editing of groups and Synchronous Copies
  • Subscribers 150
  • Views 16174
lrlsk
lrlsk over 10 years ago
Hi Everyone,
Good Day.
I am using virtuoso IC6.1.6, and my problem is that if I do some editing inside of a Group or Synchronous Copy  like. changing layer or Copying in skillmode,  the new/edited object is separated from the group, i.e it is not a member of the group which I am editing.  How should I do the copy command in skill and ensure that the new object is still part of the Group and in synced to the other copies?
Many thanks in advance for any suggestions.
BR  ~lrlsk
  • psill000
    psill000 over 10 years ago
    Talking to a rep and  a previous post I did, the syncGroups are private to Cadence. You can only edit the shape and keep the sync in XL mode only. The closest thing I have to editing the groups in skill and keeping the sync was modifying or syncing the shape coloring.
    Another option I was thinking of trying was creating my owe group by adding a property to the group to identify the groups as my sync group. This identifier would allow me to edit in L or XL. I did not have enough group editing to proceed with efforts.
    Some other useless info:
    I found if edit a shape and change the color it will not change the coloring in the other groups. However if you chop the shape after you change the color, the color will be synced with the other sync groups.
    Dont know how much it helps, but this is some of the wealth of info I have about groups.
    Paul
  • lrlsk
    Hi Paul, Thanks a lot for answering my post. That was very informative and it saves my time and effort to not dig deeper into it.
    Best Regards and Have a nice day,
    Lrlsk
