  3. Search Schematic Hierarchy for user added net property and...
  • Subscribers 150
  • Views 16246
Search Schematic Hierarchy for user added net property and return hierarchy path
rfontaine
rfontaine over 10 years ago
My goal is to open a top level schematic and scan through all of it's hierarchy and look for any cells that contain a specific user added property. When the property is found, the code would return the exact hierarchy path back to the top cell (/Xchip/Xbandgap/Xosc/XcellA). Where cellA would be the cell that a prop was found in.
  • JayR
    JayR over 10 years ago
    Not going to write the routine for you. But suffice it to say that dbGetAnyInstSwitchMaster() is your friend.
  • rfontaine
    I've already got the dbGetAnyInstSwitchMaster() portion figured out and have the code setup to recursively loop to find all instances in the hierarchy. My problem is keeping track of which instance I've descending into, such that when I find a net that matches my criteria I can report the hierarchical net name all the way back to the top level.
    Probably easiest to pass a list containing the list of instance names that you've visited down through the hierarchy into the function. So your function could be something like this:
    procedure(myRecursiveFunc(cv ... hierPathList)
       when(netIwantToReport
         printf("Net: %s/%s\n" buildString(reverse(hierPathList) "/") netName)
       foreach(inst cv~>instances
         newMaster=dbGetAnyInstSwitchMaster(inst ...)
         myRecursiveFunc(cv ... cons(inst~>name hierPathList))
    I'm showing the list being built up in reverse order because that way it's easiest for you to cons on the instance name at each call - and it will naturally get knocked off again when you return because you're not destructively modifying the list. Yes, you have to reverse it when you report - but assuming you don't have massive numbers of nets to report this should be quick enough.
