  3. converting ADEXL datasheets to PDF
  • Views 15489
NoelCFC
NoelCFC over 10 years ago
HI,
I was wondering if it would be possible to convert the HTML documents/folders created using Create->Datasheet to a single PDF document (with hyperlinks to the different sections).
thanks in advance.
    In theory yes (because you could use xsltproc or something similar to create a XSLT style sheet and convert the source XML into PDF). Or you could just save the data sheet information from your web browser into PDF. However, it's never looked particularly good whenever I've attempted to do this...
    We have looked into providing something similar built-in but it's never made it out of the door as it didn't look high enough quality.
    There have been explorations of other reporting mechanisms, but again, none of these are ready for the prime time.
    I suggest you contact customer support to request a (probably duplicate) enhancement change request.
  • NoelCFC
    thanks very much for the promptly reply, Andrew.
    I'll contact customer support. In fact, one of them is coming to our company tomorrow!
