  3. How to save a list of Viva Windows as images?
  • Views 17731
nunger23
nunger23 over 10 years ago
Hi Folks,
I'm trying to save a number of open Viva Windows at one time w/o clicking on each one and have an issue as only the displayed one is save w/ the right content while the other stay dark.
Using the following code:
path = "/home/user/"
foreach( win awvGetWindowList()
        wTitle = awvGetWindowTitle(win)
        wTitle = strcat( path wTitle ".jpg")
        saveGraphImage(?window win ?fileName wTitle ?exactCopy t ?quality 100)
Any ideas and/or hints how I could activate the related window before firing the save image command?
Thanks and best regards,
Norbert
  • skillUser
    skillUser over 10 years ago
    Hi Norbert,
    Perhaps try inserting hiSetCurrentWindow(win) before the saveGraphImage() command in your foreach loop?
    Hope it helps!
    Lawrence.
  • nunger23
    Hi Lawrence,
    sorry but unfortunately this does not help. Had tried meanwhile
    _vvSetCurrentWindow("session0" "win489" )
    which would do the job but to use it I would need to find how to get the window number from the window ID. Do you know how to get window number from window ID?
    Norbert
    Which Virtuoso subversion are you using (what does getVersion(t) return)? There have been some problems with timing with the saveGraphImage function...
  • nunger23
    I'm getting:
    getVersion(t)
    "sub-version  ICADV12.2-64b.500.1 "
    Meanwhile found a workaround looking like this but would get the first and last window number before I can start the tiny script.
    Norbert
    winNR = 224
    for( winNR 224 523
            sprintf( winNo "win%d" winNR)
            _vvSetCurrentWindow("session0" winNo )
            win     = awvGetCurrentWindow()
    ;       win     = awvGetCurrentWindow()
    ;       wTitle = awvGetWindowTitle(awvGetCurrentWindow())
    ;       hiSetCurrentWindow(win)
    The fix I'm thinking of is in IC617/ICADV122 ISR4 which is due for release tomorrow. I don't know of a way of getting the window number info for the private _vvSetCurrentWindow, sorry. I don't know for certain that it will fix the problem - but I hope so.
  • nunger23
    OK - thanks a lot!
